1993 Oldsmobile Ciera
DOUG STEVENSON
  • 1993 OLDSMOBILE CIERA
Engine Performance problem
1993 Oldsmobile Ciera 6 cyl Two Wheel Drive Automatic
where is the ambient air temp sensor on a 1993 cutlass ceria 3300 engine.
Thursday, January 7th, 2010 AT 1:00 PM
  • 109,867 POSTS
This vehicle is not equipped with an ambient temp sensor. If you are looking for the temp sending unit, it's under the hood on the passenger side located in the upper engine area (mounted in front side of water outlet).
Friday, April 9th, 2010 AT 1:20 PM
