1995 Oldsmobile Ciera Front Right Turn Signal
1995 OLDSMOBILE CIERA
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
SLUCEY
I just need help figuring out how to replace the right front turn signal bulb. IS this done from the engine compartment or from the grill of the car?
Feb 18, 2010 at 12:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
On some models you will need to remove the headlight bezel mounting screws and the bezel. Remove the mounting screws for the lamp assembly.
https://images.2carpros.com/forum/automotive_pictures/261618_1_128.jpg
After the screws are removed, pull the assembly from the vehicle. Disconnect the twist lock socket from the lens housing. To remove the bulb, turn the twist lock socket (at the rear of the housing) counterclockwise1/4turn, then remove the socket with the bulb; replace the bulb if defective. To install: Install the electrical harness to the back of the unit. Position the signal assembly, then attach to the vehicle with the mounting screws. Tighten the screws to 54 inch lbs. (6 Nm). Insert the socket to the back of the unit, then attach the headlamp bezel if removed.
Feb 18, 2010 at 3:02 PM
