1995 Oldsmobile Ciera cooling and a/c fans won't come on.
1995 OLDSMOBILE CIERA
18,000 MILES • 6 CYL • FWD • AUTOMATIC
MTUALA
The car is starting to overheat and I thought it might be the relays since we were able to jump them and get both of the fan motors to work. After replacing relays the fans still don't come on and I think it must be a faulty sensor somewhere that isn't telling them to come on but I am not sure where it would be or if this would solve the problem. Could this be it and where is it located?
May 20, 2010 at 12:28 PM
Hi mtuala, Welcome to 2carpros and TY for the donation
Check and test the coolant temperature sensor if okay could be the computer controlled of the fan relays or wiring between the motor and relay
May 20, 2010 at 12:35 PM
MTUALA
[quote:432d51c785="rasmataz"]Hi mtuala, Welcome to 2carpros and TY for the donation
Check and test the coolant temperature sensor if okay could be the computer controlled of the fan relays or wiring between the motor and relay[/quote:432d51c785] Can you tell me where the coolant sensor is located and the computer controller?
May 20, 2010 at 12:56 PM
The CTS is on left rear of engine and the controller is the computer-sorry no pic
May 20, 2010 at 3:17 PM
