1994 Oldsmobile Ciera The car wont start!
100,000 MILES • 6 CYL • FWD • AUTOMATIC
MYBABY
I replaced the fuel pump and I still cannot hear it come on.I checked the wiring to fuel pump and that is fine.Could the ECM need to be replaced?Is there a seperate fuse to theECM or can I find it in the fuse box. Or could it be the PCM?I dont know what a PCM is or where it is located!!!Can you please offer me some suggestions.
Feb 16, 2010 at 10:03 AM
  • 75,988 POSTS
Check and test the fuel pump inline fuse 15amp at right front of engine compartment on relay bracket and the fuel pump relay same location.
The computer is located behind right side of instrument panel, near shroud
Feb 16, 2010 at 10:17 AM
