1994 Oldsmobile Ciera Engine coolant leak
1994 OLDSMOBILE CIERA
96,000 MILES • 6 CYL • FWD • AUTOMATIC
COFFIN FEEDER
it has a coolant leak. i found a hole in a metal line that comes from the water pump, but thats not the whole prob. it seems to be squirting water from somewhere @ the back of the engine. It over heated today and I let it cool down & put coolant back in, now the temp gauge doesn't work & the heater doesn't get hot. I'm stumped!
Jul 7, 2010 at 3:48 PM
  • 110,244 POSTS
It sounds like there is an air pocket stoping the coolant. Have you tried bleeding the system?
As far as the leaks, I would recommend pressure testing the system to see where the leak behind the engine is coming from. It could be a heater core hose, freeze plug...
Jul 31, 2010 at 5:27 PM
