1994 Oldsmobile Ciera Check engine light comes on
GERALD CLEVELAND
  • 1994 OLDSMOBILE CIERA
Engine Mechanical problem
1994 Oldsmobile Ciera 6 cyl Front Wheel Drive 204, 00 miles
My 1994 Olds Cutlass Ciera S v6 3.1 engine. The check engine light comes on and stays on. When I get to red lights and stop signs the car cuts off. Can you tell what might be the problem?
Saturday, August 7th, 2010 AT 3:37 AM
EDWARD.S
  • 166 POSTS
Hi, When That Check Engine Light comes On, It's Telling you Something. This Means You need To Have the computer Checked for Codes. There are Various Sensors The computer looks at, If one Goes bad , or acts Up It turns on That Light. Take the car To Your mechanic And have him Check It Out.
Hope This Helps You,
Good Luck
Edward S.
Saturday, August 7th, 2010 AT 4:29 AM
