1994 Oldsmobile Ciera
1994 OLDSMOBILE CIERA
176,000 MILES • 6 CYL • FWD • AUTOMATIC
DIRTYBLUJ02
i was driving home from work everything was fine then all of a sudden felt like the car went into neutral. i pulled over and tried to shift it into a gear but nothing happened stayed in neutral. i turned the car off for a min and started it back up and i put it into drive and i shifted so i drove off and bout 20 feet it went back into neutral. i have tried this many times and it still does this let the car sit for a bit turned off then crank it and then you can drive for a few seconds then feels like it just goes into neutral again. please help i'm clueless......thanks
Mar 2, 2010 at 5:15 PM
  • 110,240 POSTS
Have you checked to make sure the fluid is full and clean? Has the check engine light come on?
Apr 9, 2010 at 3:31 AM
