1993 Oldsmobile Ciera rattleing engine parts
1993 OLDSMOBILE CIERA
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
TIM EVERHART
rattle when in neutral with engine at idle.also when hitting a small bump in the road.thank you
Sep 19, 2009 at 5:44 AM
PEAR69
  • 1,482 POSTS
Look for: a loose exhaust heat sheild, or anything that may be cracked around where the exhaust connects to the engine..Look for broken engine mounts..Does the transmission shift ok?
Sep 21, 2009 at 3:24 AM
