1993 Oldsmobile Ciera my car sputters when i take off from
1993 OLDSMOBILE CIERA
179,000 MILES • 6 CYL • FWD • AUTOMATIC
VIC21
why does my car sputter when i go to take off from a stopped position.
Apr 5, 2009 at 12:22 PM
Could be caused by the following:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Apr 5, 2009 at 12:27 PM
