1993 Oldsmobile Ciera Master Cylinder Brake Lines
1993 OLDSMOBILE CIERA
13,300 MILES • 6 CYL • FWD • AUTOMATIC
BUBBA3211
I need to know which line coming off the master cylinder is the RIGHT REAR line, the line has a hole in it, tried patching for temporary use, but the pressure is too great. I need to pinch it off at the master cylinder temporarily so fluid does not go to the right rear and the pedal doesn't go to the floor. I can't get the car into a shop for 2 weeks and the car can't be driven without decent brakes. All other brakes work fine, but no fluid will build up with the right rear leaking. Thanks.
Aug 24, 2010 at 7:53 AM
  • 110,240 POSTS
Because of the safety issues with brakes, you need to replace the line. If you can't at this time, you shouldn't drive the vehicle until it is fixed properly.
Oct 26, 2010 at 11:00 AM
