1993 Oldsmobile Ciera Help
TONGA1000
Engine Performance problem
1993 Oldsmobile Ciera 6 cyl Front Wheel Drive Automatic
After driving car for like 20 minutes it starts to shake, run rough than stalls. Will idle when in park otherwise wants to stall. I have to keep one foot on gas and one on brake and it sounds like it is on rails.
Apr 14, 2010 at 11:28 AM
  • 110,248 POSTS
Has the check engine light come on? Have you checked for vacuum leaks? Have you checked fuel pump pressure?
May 20, 2010 at 1:08 AM
