1992 Oldsmobile Ciera water pump
RRIOS
1992 Oldsmobile Ciera 6 cyl
how do you remove it
Nov 10, 2009 at 4:04 AM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1172.jpg
Nov 10, 2009 at 4:39 AM
RRIOS
unable to remove bolts on wheel what can i do
Nov 10, 2009 at 4:56 AM
BLUELIGHTNIN6
  • 16,542 POSTS
what problem are you having with the bolts? stripped, not enough access?
Nov 10, 2009 at 4:58 AM
RRIOS
pully turns as you try to remove bolts ,do not move , also by the way its a 94 not a 92
Nov 10, 2009 at 5:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
need to keep the drive belt on and tightened so you can loosen the bolts. then remove belt and finish removing the bolts.
Nov 10, 2009 at 5:16 AM
