Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Oldsmobile
Ciera
Engine Cooling
Water Pump
Replace/Remove
1992 Oldsmobile Ciera water pump
1992 OLDSMOBILE CIERA
RRIOS
MEMBER
1992 Oldsmobile Ciera 6 cyl
how do you remove it
Nov 10, 2009 at 4:04 AM
BLUELIGHTNIN6
Experienced Mechanic
Nov 10, 2009 at 4:39 AM
RRIOS
MEMBER
unable to remove bolts on wheel what can i do
Nov 10, 2009 at 4:56 AM
BLUELIGHTNIN6
what problem are you having with the bolts? stripped, not enough access?
Nov 10, 2009 at 4:58 AM
RRIOS
MEMBER
pully turns as you try to remove bolts ,do not move , also by the way its a 94 not a 92
Nov 10, 2009 at 5:11 AM
BLUELIGHTNIN6
need to keep the drive belt on and tightened so you can loosen the bolts. then remove belt and finish removing the bolts.
Nov 10, 2009 at 5:16 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
