1992 Oldsmobile Ciera engine problem
99,800 MILES • 6 CYL • FWD • AUTOMATIC
MR.GRIMM
The engine turns over fast but does not start.This is a problem that sounds like a broken timing belt but i am not sure. It doesn't have a removable distributor/rotor button.It is a coilless system.
Apr 3, 2010 at 1:34 PM
  • 110,251 POSTS
Have you checked to see if the engine is getting spark and fuel? Also, does it sounds the same as always while cranking the engine with the starter?
Apr 9, 2010 at 2:30 AM
