1992 Oldsmobile Ciera code 42?
111,000 MILES • 6 CYL • FWD • AUTOMATIC
COUPEDEVILLN
  • 10 POSTS
My mom's 92 ciera with the 3.3 just dies while driving, runs great then dies. Won't start till it cools off again, then dies once it's warm again. Ran codes and it came up with 42 bypass or est circuit. Plugs and wires are only a year old. What could cause this?
Oct 11, 2008 at 11:16 AM
JAMES W.
  • 2,394 POSTS
The EST or Ign. control modules of this ara are known for "heat break down". This sounds like the culprit for your problem. It should be located on the passenger side front, or left side of the motor next to the coil pack. Hope this helps you.
Oct 11, 2008 at 2:13 PM
COUPEDEVILLN
  • 10 POSTS
thanks. I'll give it a shot.
Oct 11, 2008 at 4:54 PM
COUPEDEVILLN
  • 10 POSTS
wasn't the problem. tested good at one parts store and bad at another. so i replaced it and bad it still died when it warm. any other ideas? i was thinking crank sensor, but there is a seperate code for that. some more help would be greatly appreciated.
Oct 12, 2008 at 9:04 AM
JAMES W.
  • 2,394 POSTS
BUMMER. Let me do a little more research and I'll get back to you yet tonight. I should have asked this before. Are you sure it is spark you're losing and not fuel? Let me know ASAP so I know I'm looking in the right direction.
Oct 12, 2008 at 1:44 PM
COUPEDEVILLN
  • 10 POSTS
ya i lose spark. I checked volts for the module pig tail while the problem was occuring. Here are the results pink-12v, dk blu/wht 0, wht/blk 0, gry/red 0, lt blu/wht 0, wht 0, blk/red 10.1, purp/wht .1, tan/blk 0, wht .1. Not sure if I should've checked ohms instead.Hope this helps. Thanks for your help.
Oct 13, 2008 at 12:08 PM
JAMES W.
  • 2,394 POSTS
When you lose spark, do you also lose the pulse to the injectors? If yes, the crank shaft position sensor
(located on the RT side of engine block) controls both spark and injector pulse. you can check injector pulse with a test light. A digital meter will not respond fast enough to show a pulse. Do you have, or have access to, a fax machine?
Oct 14, 2008 at 3:13 AM
COUPEDEVILLN
  • 10 POSTS
Probley at work, I'll have to ask. I don't have test light, best I have is 2 wires and a turn signal bulb. Will that work?
Oct 14, 2008 at 11:17 AM
JAMES W.
  • 2,394 POSTS
You can try it. It may have have too much impedence to actually flash but, you might get a small glow. They normally use a unit called a "noid light" which is a small zenon bulb, like those used in timing lights, that plugs into the injector lead. They flash like a timing light.
Oct 14, 2008 at 12:29 PM
COUPEDEVILLN
  • 10 POSTS
Ok I'll see if I can one. Do I need special tools to change the crank sensor? The book said I needed to adjust the o2 sensor and check the interrupter rings. Can I do it without the tool.
Oct 15, 2008 at 1:46 PM
JAMES W.
  • 2,394 POSTS
If the car is in the "stalled condition" and you also have no fuel injector pulse, then I would change the CPS. I takes no special tools and you should have nothing to adjust. The computer will take care of that.
Oct 15, 2008 at 2:09 PM
COUPEDEVILLN
  • 10 POSTS
Cool thank you. I'll change it and let you know.
Oct 18, 2008 at 7:46 AM
JAMES W.
  • 2,394 POSTS
Holding for a reply.
Oct 27, 2008 at 7:21 PM
