1992 Oldsmobile Ciera
1992 OLDSMOBILE CIERA
GREGORYRUSH
Air barely comes out of the vents even on high when set on a/c or fresh. When it is set on defrost or heat the air flow is fine by the windshield or the floor. What is the problem?
Sep 6, 2010 at 3:24 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
THere are vent doors that direct air flow. They are actuated by vacuum. You could simply have a vacuum leak under the dash, or one of the vents is partially stuck. When it doesn't come out the vents strong, is some of it going to the defroster or heater areas?
Oct 26, 2010 at 5:51 PM
