1991 Oldsmobile Ciera Can not get it started!
1991 OLDSMOBILE CIERA
240,000 MILES • 6 CYL • 2WD • AUTOMATIC
JASONDHADLEY
Background: The car has been sitting for about two years in my backyard, the temps out there run from 5F to 85F year round.
What I have done: I have already pulled the tank to check for varnish, there was none as I had drained the fuel system before leaving it to sit. There is fuel pushing up through the rails and the pressure is within range. The car will run on starting fluid but die the moment you stop spraying.
Any thoughts on what may cause this problem? I am thinking it may be the Ignition Module, or perhaps the fuel injectors.... but honestly not that sure!
May 7, 2010 at 4:48 PM
Check and test the injectors sounds like its not pulsing providing fuel
May 7, 2010 at 6:30 PM
