1989 Oldsmobile Ciera Trouble adjusting TPS
89,000 MILES • 6 CYL • 2WD • AUTOMATIC
CIVILTRENDS
Hi. I've isolated my problem as being the Throttle Positon Sensor.
I would like to adjust it and get the voltage right but I'm running into a problem.
The upper radiator hose is running back to a metal line that is in the way of accessing the screws for the TPS.
Do I need to remove the throttle body to make this adjustment?
This is the 3.3L engine btw.
Thanks
Jun 22, 2010 at 2:33 AM
MMPRINCE4000
  • 8,548 POSTS
If you disconnect battery for a few minutes, then reconnect, ECM will set new closed throttle voltage of TPS.
Jul 18, 2010 at 1:38 AM
