Hi. I've isolated my problem as being the Throttle Positon Sensor.
I would like to adjust it and get the voltage right but I'm running into a problem.
The upper radiator hose is running back to a metal line that is in the way of accessing the screws for the TPS.
Do I need to remove the throttle body to make this adjustment?
This is the 3.3L engine btw.
Thanks
Thanks
Jun 22, 2010 at 2:33 AM
