1989 Oldsmobile Ciera hello
METALIC38
Engine Mechanical problem
1989 Oldsmobile Ciera 6 cyl Automatic
ok i have a clicking noise in my engine when i brought it to the machanic he said it was the lifters at first when i brought it again the second time he had another person look at it and he said the engine is going cause he said the oil was getting to the top of the engine thats what making my lifters sound like that, when i open my oil cap its dry on the top but reads fine on the dip stick, but i told my friend and he said it just could be your oil pump. just want a perfessianal opition on this thank you so much guys.
Aug 10, 2009 at 12:44 PM
KHLOW2008
  • 41,812 POSTS
Hi metalic38,
Thank you for the donation.
If the head is dry, it means the oil is not getting up to the head and this is causing the ticking noise from the lifters. It could be a faulty oil pump, clogged lubricating lines or a pressure leaks somewhere.
Further analysis would have to be carried out to determine the cause. If the problem had been for a while, there is a possibility the valve trains have been damaged due to lack of lubrication and you might have to replace the head assy and its components.
If it is the oil pump, the bearings would most probably be damaged as well.
Either way, you are looking at the possibility of an engine rebuilt or transplant.
Aug 11, 2009 at 9:47 AM
2CARPRO JACK
  • 11,533 POSTS
Agreed, the lack of oil to the top usually is a sign of faulty oil pressure by-pass spring in the oil pump being broken.this prevents the pump from making enough pressure to oil the top end of the engine, but sometimes can supply enough to keep the bottom end from being damaged, depending on how long/far it was driven
Aug 11, 2009 at 9:52 AM
METALIC38
ok guys thanx alot ill have it checked out ill start with the oil pump and ill let you know ok have a great day guys thanx god bless.
Aug 11, 2009 at 5:22 PM
CUT213
  • 37 POSTS
Before you tear it down or write off the car, you might want to try this. Add about half a quart of transmission oil to the engine and drive it. Transmission fluid is really good and clearing clogs and unsticking lifters and that small amount wont harm the engine. You can drive it like that to clean out slug in the engine. But I would change the oil about week later you might see some very dirty oil at that time. It's an old school trick that really does wont with stuck lifters and clogs.
Mar 1, 2026 at 10:56 AM
  • 55,616 POSTS
Yep I agree with CUT213. this method works so I would give it a try.
Mar 2, 2026 at 12:00 AM
