1989 Oldsmobile Ciera
AMBER84411
  • 1989 OLDSMOBILE CIERA
Transmission problem
1989 Oldsmobile Ciera 6 cyl Automatic
I have a 1989 Oldsmobile Cutlass Ciera SL. I just recently had the transmission replaced in the vehicle and two days after picking the car up I noticed a grinding noise coming from the drivers side of the car. Also after parking my transmission fluid begins to leak out from under the car. It started as a slow drip but as of today it leaked out over a quart or transmission fluid. Could it be something has been knocked loose from the transmission?
Tuesday, August 31st, 2010 AT 5:59 PM
  • 109,885 POSTS
If you just had the work done, they are responsible. It is hard to say what is causing it without knowing where it is coming from on the transmission. Can you tell aprox where the leak is located?
Tuesday, October 26th, 2010 AT 5:57 PM
