Sticks in reverse
1996 OLDSMOBILE CIERA
190,000 MILES
SASSYKINZ
  • 5 POSTS
when you put the car in reverse the car feels like it gets stuck in reverse and park at the same time, then if you rock the car back and forth it will pop out, but does it every time you use reverse on the car. If you roll the car backwards first then put the car in reverse it works, but then it sticks up again and you have to go through the whole process again to unstick it. All four gears work well, can you help me please?
Apr 26, 2013 at 7:44 AM
it may be valve bdy linkeage. have a trans shop check it for you to verify
Apr 26, 2013 at 7:54 AM
SASSYKINZ
  • 5 POSTS
would this make clicking sounds when you put it in reverse?
Apr 26, 2013 at 7:59 AM
SASSYKINZ
  • 5 POSTS
There is a little box on the outside of the transmission, some type of a modulator value or something, could this be the problem?
Apr 26, 2013 at 8:02 AM
clicking, maybe the box is a park/neutral switch
roy
Apr 26, 2013 at 8:05 AM
SASSYKINZ
  • 5 POSTS
can you buy the valve body linkeage at a parts store if I wanted to repair myself?
Apr 26, 2013 at 8:15 AM
SASSYKINZ
  • 5 POSTS
thank you , you have been a great big help I will let my husband know. Thanks again for your help
Apr 26, 2013 at 8:20 AM
