1988 Oldsmobile Ciera electric engine cooling fan
TUCMAT
Engine Cooling problem
1988 Oldsmobile Ciera 6 cyl Two Wheel Drive Automatic
The fan does not come on. Where can I find the 1) temp sensor, 2) fan relay, 3) fan switch? Is there anything else I should be looking at? Thank you for your help ! !
Jul 17, 2010 at 7:50 AM
  • 75,988 POSTS
Power the fan motor direct from the battery if okay test the sensor and relay
https://images.2carpros.com/forum/automotive_pictures/12900_cts_1.gif
https://images.2carpros.com/forum/automotive_pictures/12900_fr_6.jpg
Jul 17, 2010 at 8:04 AM
