1987 Oldsmobile Ciera a
1987 OLDSMOBILE CIERA
MIKEJONES692
1987 Oldsmobile Ciera 4 cyl Front Wheel Drive Automatic
my car is shooting as out the throttle body ive replaced the throttle body,fuel injector,throttle pressure regualator valuve,tps,fuel pump,fuel filter,o2 sensor, what could it be it just dumps to much fuel in the throttle body
Mar 14, 2009 at 6:48 AM
JDL
  • 16,098 POSTS
Hello, did you do any testing before you replaced anything? Can you check for codes? Did you check for an injector pulse? Can you check the ground circuit for the fuel injector, if that is a constant ground, you got something wrong? Fuel pressure?
Mar 14, 2009 at 6:57 AM
