1987 Oldsmobile Ciera
MIKEJONES692
1987 Oldsmobile Ciera 4 cyl Front Wheel Drive Automatic
shotting gas out throttle body ive replaced the throtttle body fuel injector fuel pump fuel filter tps tpv o2 sensor computer i dont no ehat to do
Mar 14, 2009 at 6:51 AM
JAMES W.
  • 2,394 POSTS
If you mean the gas is pouring out the injector and flooding the engine, make sure you have good vacuum to the MAP sensor. If vacuum is good, change the MAP sensor.
Mar 14, 2009 at 1:44 PM
