1985 Oldsmobile Ciera No Fuel Reaching Carburetor
1985 OLDSMOBILE CIERA
SNM7786
Engine Mechanical problem
1985 Oldsmobile Ciera 4 cyl Front Wheel Drive Automatic
I have an 85 oldsmobile cutlass. It would not start so purchased a new fuel pump,filter,strainer, and fuel pump relay, fuel pump is working I can hear it but no gas reaching the fuel line. I need help.
Oct 28, 2008 at 2:03 PM
Hi snm7786 and welcome to 2carpros
When you turn key to run -do you hear the fuel pump come On for 2secs- This is where we start-if so check the fuel pressure and report back the readings
Oct 28, 2008 at 2:07 PM
