2004 Oldsmobile Bravada Vents
MRSJONES12
Air Conditioning problem
2004 Oldsmobile Bravada 4 cyl All Wheel Drive 80000 miles
The air vents in the front of the vehicle are not blowing any air out. The air and heat come out from all other vents except the ones on the front dash. How do I fix this?
Aug 18, 2009 at 8:24 PM
  • 110,248 POSTS
The vents are actuated by vacuum. Therefore, you are looking for a vacuum leak. Check under the dash and the hood for leaks. Sometimes, with the engine running, you can hear a hissing from a leak. Try that if you can't find it.
Sep 15, 2009 at 6:29 AM
