2004 Oldsmobile Bravada Transmission I think???
2004 OLDSMOBILE BRAVADA
70,000 MILES • 6 CYL • 4WD • AUTOMATIC
BRAVADA2004
When I accelerate my vehicle jerks. Its like the vehicle is trying to go faster but it trys too hard. The jerking sometimes is rough. The problem is getting worse. Even when I deccelerate its starting to do it. I've checked all fluids including the transmission fluid. All are full and look clean. To me its the transmission but could it be a fuel problem? What should be my next step?
Sep 9, 2009 at 9:51 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation.
The first thing to do with any problem like this is to have a scan done to check for any unresolved fault codes, change the fuel filter and check fuel flow & pressure as a starting point.
Mark (mhpautos)
Sep 9, 2009 at 10:03 PM
