2003 Oldsmobile Bravada Cooling fan
2003 OLDSMOBILE BRAVADA
DLINMI
Engine Cooling problem
2003 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic
Cooling fan on radiator comes on at startup and continues to run or comes on and doesn't shut off. It seems like this is a bad sensor or thermostat, whatever is telling the fan to come on. It doesn't happen every time but very often. Thank You
Mar 10, 2009 at 12:47 PM
BLUELIGHTNIN6
  • 16,542 POSTS
First inspect cooling fan relays. If both relays are OK, suspect faulty engine coolant temperature sensor.
Thanks for using 2CarPros.com!
Mar 10, 2009 at 1:34 PM
