2002 Oldsmobile Bravada tire chains
2002 OLDSMOBILE BRAVADA
BANDBG5
Tires and Wheels problem
2002 Oldsmobile Bravada All Wheel Drive Automatic 80000 miles
1)Caught in the snow. Manual says no tire ("metal link" chains. Does this include the newer "cable-type" traction devices with rubber chain tensioners? The latter are acceptable on my Honda Odysey which also has limited tire clearance.
2) If the "cable-type" are acceptable, do I put them on all four tires since it is an AWD?
Dec 22, 2008 at 3:50 AM
  • 110,240 POSTS
Hi:
I would say no to any type of tire chain because the manufacturer strongly recommends against them. However, I also recommend that you contact a dealer for their recommendation.
Dec 22, 2008 at 7:22 AM
