2002 Oldsmobile Bravada speedomitor
125,000 MILES • 6 CYL • AWD • AUTOMATIC
RPANK11
I changed the speed sensor and the speedomitor still will not work is there a 2nd sensor that i need to check
Feb 15, 2010 at 11:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
did you replace the vehicle speed sensor or the wheel speed sensor? the VSS is what the speedo uses.
if the wiring to the vehicle speed sensor (VSS) and the VSS itself are good then suspect faulty wiring at instrument panel cluster (IPC) or faulty IPC itself.
Feb 15, 2010 at 12:31 PM
