2002 Oldsmobile Bravada Spark Plugs
VERNON TRASK
2002 Oldsmobile Bravada Four Wheel Drive Automatic 120000 miles
Where will I find the spark plugs so I can change them?
Sep 8, 2008 at 9:44 AM
DBARKEMA
if it is the same as the 99' go in through the wheel wells. the passenger side will be easy, but the driver side the middle plug you have to take out with a socket and wrench do to the steering shaft is in the way. Good luck
Nov 3, 2008 at 4:51 AM
