2002 Oldsmobile Bravada Shift into reverse but transmission
SHARPS4570
Transmission problem
2002 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic
When we shift into reverse the transmission won't engage but if you put it in the other gears it works fine. Also when you put it into reverse it free rolls. When it started this it made a popping noise when it was shifted into reverse then nothing.
Jul 4, 2010 at 8:00 AM
HMAC300
  • 48,601 POSTS
have a trans guy check this out probably time for a reuild
Jul 28, 2010 at 11:20 AM
