2002 Oldsmobile Bravada shaking and stalling
CARISAJOSS
Shakes or Wobbles problem
2002 Oldsmobile Bravada Four Wheel Drive Automatic 93000 miles
I have a 2002 Bravada and have had minimal problems with it. However recently it seems that many random things are off. First thing I noticed was the idle was sometimes really low leading to stalling at a stop sign and in rush hour traffic, however if I switch to neutral and rev it's ok. Sometimes it idles high although not as often and only in neutral. The cruise control has stopped working since this started. Also when going over 50 mph and I start to brake the whole truck shakes. The other strange thing I've noticed is the whole back end seems a lot lower than it used to be. The frame is closer to the tires than I remember and the rear door used to be higher than me 5'3 and now I hit my head on it. Any ideas would be greatly appreciated!!
Apr 30, 2008 at 6:40 AM
RHALL77
  • 3,361 POSTS
is it setting a check engine light? as for the brakes it sounds like the brake rotors need to be machined. do you know if the rear of the vehicle has air ride suspension?
Apr 30, 2008 at 7:14 AM
CARISAJOSS
Thank you for the reply. Yes, it does have air ride suspension and now that I'm thinking of it I haven't heard it turning on and off like it used to. Does that affect anything other than the height?
Apr 30, 2008 at 7:28 AM
CARISAJOSS
Sorry, periodically the check engine light does come on. But not all the time.
Apr 30, 2008 at 7:29 AM
RHALL77
  • 3,361 POSTS
your engine performance problem most likely is caused by what ever is setting the check engine light. i would have it scanned at your local shop or dealer
Apr 30, 2008 at 7:31 AM
