2002 Oldsmobile Bravada motor dies
123,026 MILES • 6 CYL • AWD • AUTOMATIC
FELTON H MILLER
I have a 2002 bravada only put 4000 miles and th
e battery was tookin out and replaced. Ever since the if I turn on the a.c the motor dies and it says low oil pressues.any ideas what worng?
Mar 30, 2010 at 10:41 AM
LEGITIMATE007
  • 5,121 POSTS
well, theoretically, when you turn your a/c on the idle is supposed to raise a bit too. this is why they always say,"the a/c uses up gas" because the idle has to raise in order to keep the car running. the idle air control valve should adjust the idle when you turn it on. the oil pressure is another problem all by itself, i dont know if you your oil is low, or the sending unit is just bad and is giving a false reading. or that you may need a new pump. the repair shop will have to determine that.
Apr 4, 2010 at 7:10 AM
