my bravada has a mind of its own. the first time trying to start it and it runs fine fuel pressure is 52 psi. as soon as i shut it off the pressure falls to zero and will not refire. let it sit for 20 minutes and the same story follows.sometimes it has to sit longer before it will restart and sometimes it will stall before i turn it off and pressure is zero. i just recently had a problem getting it to start at all . ended up being either the neutral safety or the ignition switch,replaced both of them. i don't know if its related or not but the compressor for the air ride quit working!your help is greatly appreciated.THANK YOU!!!
Dec 4, 2008 at 12:22 PM
