2002 Oldsmobile Bravada broken 4x4
72,000 MILES • 6 CYL • 4WD • AUTOMATIC
HALFCRAZY
my 4 wheel drive dont work . i have smarttrack in my 2002 olds bravada. i jacked the car up n put on jack stands then started the car n put in drive . all 4 wheel spun i staied in the car so i dont know if the front wheels had any power ? but thay looked 2 spin slower then the rear wheels also after a minit the abs light came on .i just drove in sum snow last night n my 4x4 did not work whats wrong ??????[img:fdecb0b7ed]http://www.2carpros.com/forum/automotive_pictures/286133_Picture_022_1.jpg[/img:fdecb0b7ed]
Dec 13, 2008 at 12:53 PM
SWILLIAMS
  • 597 POSTS
Sounds like the ABS sensors may have a problem. They are used to sense the difference in wheel speed to activate the SmartTrack system. If there is an ABS fault the system will not operate. The ABS light will come on when the wheels are off the ground.
Dec 14, 2008 at 11:28 AM
BAUER30
Im having the same problems. My ABS service light is on, and when i use my brakes, right before a complete stop, it makes some noise and the brake pedal kicks back on my foot, like when the abs is working, but it is happening all the time in my car even on dry surfaces. Few days ago i noticed that the AWD is not working while i was driving on some snow. I had no service light on for AWD but i had service brakes messages and my mechanic after reading the codes said i have bad sensors. You think after i fix my brakes i will have my AWD working as well?? Thanks in advance.
Dec 25, 2008 at 1:00 PM
