2001 Oldsmobile Bravada Fuel Pump
98,562 MILES • V8 • AWD • AUTOMATIC
CWILLIS
I am not getting juice to the fuel pump. It will come on one time then go off. When I use a test light, turn the key on, it will show a light then go off before I turn the key off. It then won't come back on for a few minutes. After a while, if I turn the key on again, it will light the test light but won't maintain it.
Aug 19, 2010 at 1:09 PM
  • 75,988 POSTS
If the fuel pump is coming on for 2secs and dies off-check the fuel pressure if okay -check and test the fuel pump/oil pressure sending unit
Aug 19, 2010 at 1:18 PM
