2001 Oldsmobile Bravada fuel pump
2001 OLDSMOBILE BRAVADA
103,000 MILES • 6 CYL • AWD • AUTOMATIC
DJFATBALLZ
replaced fuel pump,filter, relay and fuses still no pressure.hooked old fuel pump to the battery with two jumper wires and it works.is there a reset button .or something that could have tripped.
Aug 30, 2008 at 12:16 PM
  • 110,240 POSTS
Hi:
Is the vehicle getting spark? Also, does it have a factory security system? If you go to the relay box, remove the fuel pump relay, and check for power, are you getting any?
Nov 7, 2008 at 2:42 AM
