2001 Oldsmobile Bravada Check Engine Light and Fan
62,500 MILES • 6 CYL • AWD • AUTOMATIC
TNT_DREAMCHASER
I just purchased this vehicle about 6 weeks ago. 2 weeks after I bought it the check engine light came on. I took it to my mechanic who tested the computer and said that it came on due to me not closing the cap tight enough. I also had them check the heater as it was only blowing luke warm air and never gets hot, also the air will only come through the floor vents and defroster warm, if I turn it to hand/face vents it feels like it is coming from the a/c. They reset the computer and put a new thermostat in the vehicle and said they unplugged one of the vents. The check engine light came on again yesterday and has not/will not go off and the new thermostat didn't change a thing. I know it isn't a problem with the cap being tight enough because I turn it 3-4 times around and my tank was over half empty this time when it came on. I would like to have these problems fixed but I hesitate to take it back to my normal mechanic since it doesn't seem to have done any good the first time. Any suggestions on the problems I might be having?
Dec 31, 2008 at 3:24 PM
SWILLIAMS
  • 597 POSTS
The CEL should have a code that would help a LOT. There are a lot of items that can turn it on.
As for the heat problem. It sounds like a blend door has a problem. There is one that directs the air through the heater core or the A/C core, Another directs the air to the different vents.
A vacuum leak up front could be causing both problems.
Was this a private sale or dealer? If it was a dealer it should have some warranty on it.
Jan 3, 2009 at 9:20 AM
TNT_DREAMCHASER
Unfortunately, the warranty I have doesn't cover much and the dealership is about 350 miles away. I am going to make an appointment to get it in again and I'll post what code(s) are coming up.
Jan 12, 2009 at 11:42 PM
