2000 Oldsmobile Bravada slippage
185,000 MILES • 6 CYL • 4WD • AUTOMATIC
TLANDIS5
Thae transmission is slipping in my 2000 bravada. checked the tranny fluid and its over full. do you think its the pump?
Jul 16, 2009 at 10:21 AM
  • 110,248 POSTS
First, remove the excess fluid. See if that takes care of the problem.
Sep 16, 2009 at 2:06 AM
AD142314
  • 6 POSTS
With 180,000 miles the transmission is due for a rebuild.I rebuild transmissions so it more then likely that your clutches are slipping.I rebuilt my 1997 Bravada at 142,000 miles.
Nov 6, 2009 at 3:40 PM
  • 110,248 POSTS
I do agree with ad142314, it could just need rebuilt. Have you tried to remove the excessive fluid? Did it make any changes?
Nov 7, 2009 at 3:01 PM
