2000 Oldsmobile Bravada distributor and timing
BIGBOB42
Engine Mechanical problem
2000 Oldsmobile Bravada 6 cyl Four Wheel Drive Automatic
where is the dial for the timing located at on the block. and how do you install the distributor as well..help...please...asap
Dec 27, 2009 at 3:05 PM
BIGBOB42
[quote:690531db9c="bigbob42"]Engine Mechanical problem
where is the dial for the timing located at on the block. and how do you install the distributor as well..help...please...asap[/quote:690531db9c]
tried and no luck with chilton or any of them...
Dec 27, 2009 at 3:09 PM
