1999 Oldsmobile Bravada ignition is stuck
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
JLREEVES81
This morning I went to start the bravada and after i turned it over nothing happened and the key became stuck. I had no power so i figured the batt was bad. I took it in and bought a new one, brought it home ,hooked up the batt. and the power flickered on for a second and it released the key. i put the key back in and it locked up again. i dissconnected the batt. and tried again but the key remains stuck, i cant shift out of P, and there is a strange noise comming from the relay box under the hood. what i thought was gonna be a easy fix is turning out to be a real pain in the ass. any suggestions would be greatly appreaciated.
Jan 3, 2010 at 7:28 AM
BMRFIXIT
  • 19,053 POSTS
Suspect Battery terminals
remove check and clean or replace if needed
Jan 3, 2010 at 10:24 PM
JLREEVES81
the terminals look clean and have a rubber casing around it. would my ignition relay cause this problem?
Jan 4, 2010 at 12:44 AM
BMRFIXIT
  • 19,053 POSTS
Make sure that the terminals clean under the cover
the way you described it sounds as bad connection
most common place to look is at terminals
Jan 4, 2010 at 5:33 AM
JLREEVES81
everyone says the samething but the terminals are fine. a tow truck is stopping by to pick it up today and figure it out. THANKS FOR NOTHING!
Jan 6, 2010 at 3:08 AM
BMRFIXIT
  • 19,053 POSTS
Very welcome
hope all work fine for you
Jan 6, 2010 at 8:55 AM
STUVAN
I have the same problem what did you find out?
Feb 25, 2010 at 1:21 AM
