1999 Oldsmobile Bravada I need heat
1999 OLDSMOBILE BRAVADA
TSMALL1
Heater problem
1999 Oldsmobile Bravada All Wheel Drive Automatic
I have a 1999 Bravada Oldsmobile. The blower is on and working, but is blowing cold air. I just recently had a thermostat put in and had my cooling system flushed. The heat is still not coming threw. i appreciate any suggestions that I can get to resolve this problem before winter sets in. Thank you Tonia
Nov 18, 2009 at 9:01 AM
Test the thermostat and check the heater core if its clogged-up if okay could be air mix/blend/mode door problem , vacuum and actuator-HVAC control module
Nov 18, 2009 at 9:01 PM
