1999 Oldsmobile Bravada headlights
12,100 MILES • 6 CYL • 4WD • AUTOMATIC
DBARKEMA
I recently had the driver side front fender and bumper repaired. The hit damaged the wiring harness for the headlights and whatever else on that side. A new headlight was put in and all was put back together. The harness was spliced back together. The driver side headlight will not broadcast a beam. It lights like a nightlight and will not change with brights or regular beam. The daytime running lights work. The directional works. the fog works. What could be causing the lack of power to the light?
Thanks
Nov 3, 2008 at 4:48 AM
  • 110,248 POSTS
Hi:
Have you taken the car back to the body shop? It sounds like they put something together wrong. It sounds like a combination of a ground problem and both wires (hi / low beam) wern't repaired.
Nov 6, 2008 at 5:30 AM
