engine clicking noise while pressing the gas?
PLUTO
Engine problem
1999 Oldsmobile Bravada 6 cyl Wheel Drive Type unknown Automatic 105000 miles
What does it mean when your car makes a clicking noise while pressing the gas?
Jan 11, 2008 at 8:15 AM
  • 55,694 POSTS
This click noise can be caused by one of two things either you have a loose spark plug or a broken flex plate which means you will need to remove the transmission.
Here is a guide to help you check the spark plugs
https://www.2carpros.com/articles/how-to-change-spark-plugs
This will show you how to remove the transmission to replace the flex plate diagrams (below)
Please let us know what you find.
Cheers, Ken
Jan 11, 2008 at 8:23 AM
PLUTO
Yep I checked the plugs they where okay it was the flex plate it cost me 450.00 to have it fixed. Thanks for your help I love this site.
Jan 15, 2008 at 8:13 AM
DHALL
1993 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic
Every now and then once I reach 10mph, I loose about 50% power. The engine still runs but I have very little power. When the power is deduced I hear a single click come from under the hood. The problem will last for a few days and then everything will return to normal. The engine does not misfire when this occurs.
Thanks
Mar 13, 2018 at 8:58 AM (Merged)
  • 75,988 POSTS
Do you have a check engine light?
Have these components checked below
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
