Turn Signal Flasher
1998 OLDSMOBILE BRAVADA
102,000 MILES • 6 CYL • AWD • AUTOMATIC
DVGORSKI
Where is the turn signal flasher located on this vehicle?
Apr 7, 2009 at 2:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Front seating area, passenger side, behind dash, under access panel, mounted in fuse panel in glove compartment behind
Thanks for using 2CarPros.com!
See diagram below for location of the flasher relay in your truck
Apr 7, 2009 at 4:17 PM
MTILL47
where is the turn signal flasher located on my 96 bravada
Jan 12, 2019 at 10:06 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Front seating area, driver side, driver side of steering column, behind instrument cluster, mounted in convenience center
ENTELLIJENCE
  • 10 POSTS
Turn signals come one sporadically, hazard lights not at all. Could this be the turn signal relay needing replaced?
Jan 12, 2019 at 10:07 PM (Merged)
  • 110,240 POSTS
Do you mean they only work once in awhile?
ENTELLIJENCE
  • 10 POSTS
Yes sometimes they will work other times they wont, hazard lights dont work at all. All the other lights work fine.
  • 110,240 POSTS
If they light up but not flash, then the flasher needs replaced. If nothing turns on when actuated, then I would suspect the switch is going bad.
ENTELLIJENCE
  • 10 POSTS
If they decide to work, they light up and blink, So replacing the multi switch is the way to go? Also the most expensive way lol
  • 110,240 POSTS
I feel that is where the problem is coming from. However, have it tested before purchasing a new one.
ENTELLIJENCE
  • 10 POSTS
How do you have it tested? Remove and take it to like Oreillys?
AIR23MAN
Electrical problem
1997 Oldsmobile Bravada 4 cyl All Wheel Drive Automatic
Earlier today when i left for work i noticed that my blinkers are not working, they make absoulutely no noise when i turn em either way could it maybe be a fuse or another problem i do have a 97 olds bravada so i'm hoping someone can help me out thanks.
Ricky
BLUELIGHTNIN6
  • 16,542 POSTS
hello and thanks for donating!
are the indicators in dash coming on at all? if not, check for faulty signal fuse. also check turn signal flasher relay if fuse is OK. if both are OK then suspect faulty signal (multi function) switch.
  • 110,240 POSTS
Some parts stores will do it for you. You will need to call and ask.
AIR23MAN
tHANKS
RJM
ENTELLIJENCE
  • 10 POSTS
Last question i promise, can they test it on the vehicle or do i need to remove it?
2 LINSEY
  • 287 POSTS
Hi, Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
  • 110,240 POSTS
It would be tested differently on the car and I doubt a store would do it. Please, contact the stores around you to make sure they can do it before you go to all the trouble. Also, make sure the battery is disconnected at least 30 minutes before you start working around the air bag.
ENTELLIJENCE
  • 10 POSTS
So i replaced the multi switch hazard lights come for a bit then shut of on there own.also when i hit the brake the left turn signal light comes on.i don't know where to go from here. Could it be a sign of a bigger electrical problem?
  • 110,240 POSTS
You need to find a wiring schematic and double check all the connections. I have access to one, but I have no way to copy and paste it.
TOWERSITE
I put the left signal on the lite on the dash lit but did not blink. The same for the right a couple miles later. Got home tried both again neither lit. 4-way flashers work , fuse is good , reverse lights ok , same fuse as turn signal , checked bulbs when 4-way flashers were on - ok . Is there a relay for the turn signals ? & if so where is it located ?
2CARPRO JACK
  • 11,533 POSTS
It is in the power distribution center (below and in front of radio)
ENTELLIJENCE
  • 10 POSTS
I wired it exactly the way it was. I'll take it to this mechanic friend of mine this weekend to get a second opinion, maybe he can see something i cant.
  • 110,240 POSTS
Let me know what you find.
