1998 Oldsmobile Bravada poor gas millage/rough idle/smell g
1998 OLDSMOBILE BRAVADA
130,000 MILES • 6 CYL • AWD • AUTOMATIC
GGAISBAUER
idles rough, poor gas millage, smell gas and hard to start after first start up and run for a short period of time. i was told by an auto store that it was a vacumn leak. were would i look for this leak. thanks very much for your help.
Feb 11, 2010 at 2:53 AM
If this is a Vortec CPI spider injection engine-you need to check the fuel pressure. Pressure regulator could be leaking open upper intake plenum and investigate also check the nut kit/poppet valves
Feb 16, 2010 at 5:20 AM
