Engine Mechanical problem
1998 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic
I am trying to replace the oil lines from the oil filter adapter to the engine. everything is off but the lines will not come out. They are getting stuck between the oil pan and transfer case. I need to know if there is a way of removing them with basic hand tools, or if I need heavy equipment to lift the engine about a 1/4 inch so it can slide past.
Mar 26, 2010 at 12:20 PM
