1998 Oldsmobile Bravada fuel pump
1998 OLDSMOBILE BRAVADA
116,000 MILES • 6 CYL • AWD • AUTOMATIC
JCMERC
Hello i have a 98 olds bravada that i will be replacing the fuel pump for the 3rd time in it since january the gas tank is clean no debri all the wiring harnass is fine i have replaced the plug for the fuel pump both times i put in a new pump i replaced the fuel pressure regulator and fuel filter also yet i get a no start once in awhile and then when it sits it will start and run fine what else should i check on this? thank you
Jul 31, 2008 at 6:56 AM
Do you have a check engine light?
When it refuses to start-immediatel check the fuel pressure and look for spark this will narrow it down is to where its coming from.
Jul 31, 2008 at 7:02 AM
JCMERC
The only check engine light that came on was for the vapor recovery system the first time i replaced the fuel pump i busted the single rubber line on the gas tank that goes into a black plug towards the front of the suv in the tank and have sinced repaired it and light went off and some times there is fuel pressure when it wont start and sometimes there isnt
Jul 31, 2008 at 1:32 PM
FLYING BIKER
[quote:0637600912="jcmerc"]Engine Mechanical problem
1998 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic 116000 miles
Hello i have a 98 olds bravada that i will be replacing the fuel pump for the 3rd time in it since january [/quote:0637600912]
I am about to replace mine in the morning on a 2000 Olds Bravada. In all that I have read. I have been told to use either the Bosch or the AC Delco replacement as the others seem to have a high failure rate. I don't know if that is what you are using but it seems to be a consensus.
Jul 31, 2008 at 6:21 PM
JCMERC
I always thought carter fuel pumps were good but im kinda stuck with them unless if i take this one back and they let me upgrade on1
Aug 1, 2008 at 6:43 AM
